Oasis 027205 Waste Gasket
  • Item #: 102561
  • Model: 27205
The 027205 Oasis Waste Gasket fits between the basin and the drain assembly to create a watertight seal. The foam gasket has a flat bottom to seal to the drain assembly. The top of the gasket is formed to match the angle of the drinking fountain basin. When the basin screw is tightened the gasket is compacted to create a watertight seal.
17 Ready To Ship Today
Posted on Friday, December 14, 2012 on product Oasis 027205 Waste Gasket
    A: Yes, you will want to put a little sealant on the flat bottom side of Oasis 027205 Waste Gasket.
    Posted by Kully Supply on Friday, December 14, 2012
