Central Brass 0360 Bubbler Head & Flange
  • Item #: 150691
  • Model: 360
  • Manufacturer: Central Brass
If you are looking to find Central Brass products quickly and easily, you’ve come to the right place. This Central Brass 0360 Bubbler Head & Flange is a direct replacement product manufactured by Central Brass. Order this Central Brass 360 today and you will have your Central Brass project completed in no time at all.
  • Includes Shank
2 Ready To Ship Today
Posted on Monday, December 11, 2017 on product Central Brass 0360 Bubbler Head & Flange
    This Central Brass 0360 Bubbler Head & Flange (Part #150691) has a water adjustment screw under the push button.
    Unthread the top nut and remove the push button. Use a straight blade screwdriver on top of the brass regulator screw to adjust the water flow.
    Clockwise to increase the stream height
    Counterclockwise to decrease the stream height
    Posted by Kully Supply on Monday, December 11, 2017
