Elkay 98466C Solenoid Valve with Regulator
  • Item #: 133488
  • Model: 98466C
  • Manufacturer: Elkay
This Elkay Solenoid Valve 98466C is an electrically controlled water control valve found in many drinking fountains. When a user presses the pushbar, an electrical signal is sent to this valve which opens and lets water flow for as long as the pushbar remains pressed.
View Similar
  • Post-July 2008
  • 120V Solenoid Valve
  • Built-In Regulator
  • Built-In Y-Strainer
  • 1/4” Inlet and Outlet
Posted on Tuesday, June 20, 2017 on product Elkay 98466C Solenoid Valve with Regulator
    The Voltage on this Elkay 98466C Solenoid Valve (Part #133488) is 110-120 Volts AC.
    Posted by Kully Supply on Tuesday, June 20, 2017
