Elkay EZH2O LZS8WSLK Filtered Drinking Fountain with Bottle-Filling Station
  • Item #: 137944
  • Model: LZS8WSLK
  • Manufacturer: Elkay
The Elkay EZH2O Bottle Filler Series is Elkay’s most popular bottle filling station. The Drinking Fountain and Bottle Filler are combined into one space saving and ADA (Americans with Disabilities Act) compliant unit.
  • Refrigerated: 8GPH
  • Light Gray Granite
  • Filtered
This Item Typically Ships in 1-2 Weeks
    A: The bottle filler should only run when sensing a bottle in front of it, once you pull the bottle away it should shut. The 30 second time out is only if someone would set a bottle in front of the sensor and walk away and they forget to come back and retrieve the bottler.
    Posted by Kully Supply on Wednesday, March 5, 2014
    A: The water flow from the bottle filler is not adjustable. If you are having an issue with the flow you may want to check to be sure the water inlet valve is completely open and that there are no kinks in the tubing.
    Posted by Kully Supply on Tuesday, February 4, 2014
