Elkay EZH2O LZSTL8WSLK Filtered Dual-Station Drinking Fountain with Bottle-Filling Station
  • Item #: 138077
  • Model: LZSTL8WSLK
  • Manufacturer: Elkay
This Elkay EZH2O LZSTL8WSLK Bottle-Filling Station with filter is a complete cooler and bottle-filling station in a consolidated space saving ADA compliant design. This versatile dual-station cooler design allows for standard cooler installation of the higher station on the left, and lower unit on the right, or the alternate reverse cooler installation. Touchless, sensor activation (bottle filler) designed for easy use; easy-to-operate push-bar activation (bubbler).
  • Refrigerated: 8GPH
  • Light Gray Granite
  • Filtered
This Item Typically Ships in 1-2 Weeks
    The 3/8" connection on the Tee in this Elkay EZH2O LZSTL8WSLK Bi-Level Bottle Filling Station (Part #138077) will connect to the water line that comes into the Fountain from the Bottle Filler.
    Posted by Kully Supply on Friday, August 11, 2017
