Posted on Tuesday, September 12, 2017 on product Elkay EZSTL8LC Dual Drinking Fountain
If both of your Elkay Bi-Level Drinking Fountains have water flow issues, it is likely that Calcium buildup is forming in your bubbler or you have a Defective Regulator Valve.
We recommend replacing the Elkay 92715C Flexi-Guard Bubbler Head Kit (Part #102494) and the Elkay 98531C Regulator Valve Kit (Green Spring) (Part #140048) on both fountains to ensure this issue is resolved.
Posted by Kully Supply on Wednesday, September 13, 2017
0
Answer
Posted on Tuesday, November 5, 2013 on product Elkay EZSTL8LC Dual Drinking Fountain
0voteA: Yes, you are able to get just the right side only. (Part#154917)Posted by Kully Supply on Tuesday, November 5, 2013
Posted on Wednesday, August 28, 2013 on product Elkay EZSTL8LC Dual Drinking Fountain
0voteA: These units come from the factory set at 50 degrees or colder. However, than can be adjusted to be colder than that by adjusting the cold control thermostat.Posted by Kully Supply on Wednesday, August 28, 2013
