0
Answer
Posted on Monday, October 2, 2017 on product Elkay 98531C Drinking Fountain Valve and Regulator Kit (Green Spring Cartridge)
If this Elkay 98531C Regulator Valve Kit (Green Spring) (Part #140048) is leaking after installation, we recommend checking that the Cartridge Regulator is seating properly in the Housing and the Retaining Nut is threaded tightly.
There are two slots in the bottom of the Housing where the bottom of the Cartridge sits. If the Cartridge isn't positioned properly, it can cause the Valve to leak.
Posted by Kully Supply on Tuesday, October 3, 2017
