Elkay EZH2O LVRCGRN8WSK GreenSpec Filtered Vandal-Resistant Drinking Fountain with Bottle Filler
  • Item #: 154840
  • Model: LVRCGRN8WSK
  • Manufacturer: Elkay
If you are looking to find Elkay products quickly and easily, you’ve come to the right place. This Elkay EZH2O LVRCGRN8WSK GreenSpec Filtered Vandal-Resistant Drinking Fountain with Bottle Filler is a direct replacement product manufactured by Elkay. Order this Elkay LVRCGRN8WSK today and you will have your Elkay project completed in no time at all.
  • Refrigerated: 8GPH
  • Stainless Steel
  • Filtered
  • Vandal-Resistant
  • GreenSpec Listed
This Item Typically Ships in 1-2 Weeks
    There are two Bottle Filling Station styles. The styles can be distinguished by the Model Number.
    A) Model Numbers ending with P have a filter that is automatically reset.
    The Filter Light is automatically reset when the RDIF sticker on the new filter is scanned in by the Bottle Filling Station. The RDIF sticker is a white sticker on the filter. If the sticker does not line up correctly with the scanner or is missing then the Filter Light will not automatically reset.
    B) Model Numbers ending without P need to be manually reset following the instructions below.
    1) Depress the program button for approximately 2 seconds until
    the display changes then release. The display will change and
    scroll through two messages: “RST FLTR” – Reset Filter Monitor
    “SETTINGS” – System Settings Sub Menu
    If the program button is not pushed again the display will scroll
    through the two messages above for three cycles and then default
    back to bottle count and be back in run mode.
    2) When the display changes to “RST FLTR”, depress the button
    again. The display will change to show “FLTR =”. Depress the
    button again and the display will show “FLTR =0”
    3) The Green LED should be illuminated indicating that the visual
    filter monitor has been reset.
    Posted by Kully Supply on Tuesday, March 28, 2017
