Posted on Thursday, June 29, 2017 on product Elkay 55996C Strainer
Yes, if this Elkay Strainer 55996C (Part #102483) is leaking, we recommend getting a replacement Strainer.
To disconnect the existing Strainer, you will press in the fittings on each end to free the water lines. As you're pressing in the fitting, pull out the water line.
Here is a video that illustrates how to remove the water lines from the quick connect fittings in your Drinking Fountain - http://www.kullysupply.com/blog/2012/08/02/test-video-post/.
Posted by Kully Supply on Thursday, June 29, 2017
0
Answer
Posted on Friday, January 4, 2013 on product Elkay 55996C Strainer
0voteA: The 55996C strainer has release collars on it. Push in the dark gray plastic piece that is next to the copper lines. While doing this, pull and gently twist the copper line to remove it. If the copper line will not come out of the strainer you will need to cut the lines.Posted by Kully Supply on Friday, January 4, 2013
