The Halsey Taylor 98324C Cane Apron (Part #133460) is attached the the fountain using the screws that are provided. Below are the installation instructions and required tools to attach the Cane Apron.
Required Tools
• Pinned Torx Head Driver
• Power Drill with 1/8” Drill Bit
• Hammer and Center Punch
1. Using cane apron as a template use a center punch to mark hole locations on front of left and right side panels.
2. Drill 1/8” diameter holes at marked locations. (Center punch hole locations before drilling). When drilling the right hand hole on refrigeration units, be certain to drill straight.
CAUTION: Keep the drill bit away from the refrigeration condenser. If the drill damages or punctures the condenser refrigeration tubing severe and expensive damage to the refrigeration system will result.
3.Loosen and remove (2) front screws from underside of cooler dispenser panels.
4. Install cane touch apron to underside of cooler dispenser panels and reuse fasteners removed in step 3 above.
5. Attach lower edges of apron to cooler side panels with screws provided. (Using two holes drilled in step 2 above)
0voteA: The Halsey Taylor 98324C Cane Apron (Part #133460) is attached the the fountain using the screws that are provided. Below are the installation instructions and required tools to attach the Cane Apron. Required Tools • Pinned Torx Head Driver • Power Drill with 1/8” Drill Bit • Hammer and Center Punch 1. Using cane apron as a template use a center punch to mark hole locations on front of left and right side panels. 2. Drill 1/8” diameter holes at marked locations. (Center punch hole locations before drilling). When drilling the right hand hole on refrigeration units, be certain to drill straight. CAUTION: Keep the drill bit away from the refrigeration condenser. If the drill damages or punctures the condenser refrigeration tubing severe and expensive damage to the refrigeration system will result. 3.Loosen and remove (2) front screws from underside of cooler dispenser panels. 4. Install cane touch apron to underside of cooler dispenser panels and reuse fasteners removed in step 3 above. 5. Attach lower edges of apron to cooler side panels with screws provided. (Using two holes drilled in step 2 above) If you have any other questions our experts are here to help! Call or text 800-518-5388Posted by Kully Supply on Tuesday, February 28, 2017
