Elkay 98535C Overload, Relay and Cover Kit - 115V
  • Item #: 140041
  • Model: 98535C
  • Manufacturer: Elkay
If you are looking to find your Elkay repair parts quickly and easily, you’ve come to the right place. This Elkay 98535C Overload, Relay and Cover Kit – 115V is a direct replacement part manufactured by Elkay. Order this Elkay 98535C today and you will have your Elkay repairs completed in no time at all
15 Ready To Ship Today
Posted on Tuesday, September 12, 2017 on product Elkay 98535C Overload, Relay and Cover Kit - 115V
    Here are the steps to replacing a defective Relay & Overload Assembly on a Drinking Fountain:
    1) Remove the screws at the bottom of the fountain and remove the wrapper panel.
    2) Unplug the Drinking Fountain from the wall outlet.
    3) Locate the Plastic Cover on the side of the Compressor that hides the Relay & Overload.
    4) Remove the Relay Cover by pressing down the Slot at the top of the cover using a straight blade screwdriver.
    5) Remove the Relay first, then the Overload. They will simply pull off of the Compressor like a plugin.
    6) Plugin the Overload, followed by the Relay and Snap the Cover back onto the Compressor. The Relay will be secure after you hear two clicks.
    7) Plug the Drinking Fountain back into the wall outlet and secure the wrapper panel back onto the fountain.
    Posted by Kully Supply on Tuesday, September 12, 2017
