Halsey Taylor HTV-8-BL-Q-TTG Voyager Bi-Level Barrier-Free Water Cooler (Discontinued)
  • Item #: 102369
  • Model: HTV-8-BL-Q-TTG
  • Manufacturer: Halsey Taylor
The HTV Series is Halsey Taylor’s contemporary drinking fountain line. The series features a smooth design and unique two-tone polymer construction. Easy-touch controls are used for simple operation.
The HTV-8-BL-Q-TTG Water Cooler is a bi-level unit with push bars that can be activated from the front or sides. The higher unit is on the left.
  • Refrigerated: 7.5GPH
  • Two-Tone Gray
    A: The issue is going to be either the solenoid valve sticking open or a switch. What you can do is activate the unit and immediately unplug it and if the water does run after it is unplugged than you will need to replace the solenoid, if it shuts off than it is a switch.
    Posted by Kully Supply on Tuesday, November 13, 2012
