Haws 5871 Push Button Valve Kit (Discontinued)
  • Item #: 102556
  • Model: 5871
  • Manufacturer: Haws
The Haws 5871 Push Button Valve Kit is for use in Haws drinking fountains. It is located behind the push button.
The push button valve keeps the drinking water stream constant throughout the drinking process.
Posted on Friday, April 7, 2017 on product Haws 5871 Push Button Valve Kit (Discontinued)
    This Haws 5871 Push Button Valve Kit (Part #102556) is no longer available and has been replaced by the Haws 5874PB Push Button and Valve (No Flange) (Part #134001).
    The Haws Replacement Valve 5874PB (No Flange) works on all Drinking Fountains, unless you have a Drinking Fountain that is recessed in the wall. If you have a Recessed Drinking Fountain you will need the Haws 5874PBF Push Button and Valve (With Flange) (Part #102775).
    Posted by Kully Supply on Friday, April 7, 2017
