Oasis 013059-005 Drinking Fountain Valve Stem Assembly
  • Item #: 102562
  • Model: 013059-005
This Oasis Valve Stem 013059-005 is a twist style operated valve stem. The valve stem is threaded into a valve body or a bubbler head. When the handle is pushed the stem turns and moves the seating surface away from the seat which allows water to flow. The spring loaded stem returns to the closed position when the handle is released.
20 Ready To Ship Today
Posted on Monday, October 30, 2017 on product Oasis 013059-005 Drinking Fountain Valve Stem Assembly
    The location of the Water Flow Adjustment varies from model to model.
    Typically, the Water Flow Adjustment for this Oasis Valve Stem Assembly 013059-005 (Part #102562) is located within the bubbler.
    We recommend calling our Drinking Fountain Experts for more detailed information on how to adjust the water flow on your Drinking Fountain at 800-518-5388 or by chatting with us online.
    Posted by Kully Supply on Tuesday, October 31, 2017
Posted on Wednesday, February 6, 2013 on product Oasis 013059-005 Drinking Fountain Valve Stem Assembly
    A: A special tool is not required for removing the stem assembly from the valve body. An adjustable or fixed wrench will work to remove the stem assembly.
    Posted by Kully Supply on Wednesday, February 6, 2013
