Oasis 027040-022 Thermostat
  • Item #: 106821
  • Model: 027040-022
If you are looking to find your Oasis repair parts quickly and easily, you’ve come to the right place. This Oasis 027040-022 Thermostat is a direct replacement part manufactured by Oasis. Order this Oasis 027040-022 today and you will have your Oasis repairs completed in no time at all
1 Ready To Ship Today
Posted on Tuesday, March 28, 2017 on product Oasis 027040-022 Thermostat
    The Oasis 027040-022 Thermostat (Part #106821) is designed to keep the water temperature between 39-45 degrees. The water temperature may vary depending on the environment that the drinking fountain is in.
    Posted by Kully Supply on Tuesday, March 28, 2017
Posted on Wednesday, February 15, 2017 on product Oasis 027040-022 Thermostat
    A: The Oasis 027040-022 Thermostat (Part #106821) is designed to keep the water temperature between 39-45 degrees. The water temperature may vary depending on the environment that the drinking fountain is in. If you have any other questions our experts are here to help! Call or text 800-518-5388
    Posted by Kully Supply on Wednesday, February 15, 2017
