Oasis F140R NON-REFRIGERATED In-Wall Drinking Fountain
  • Item #: 106125
  • Model: F140R
The RADII Series is Oasis’ drinking fountain line featuring a distinctive and space-saving design. The series is barrier-free and meets ADA standards when properly installed.
The F140R Non-Refrigerated Drinking Fountain is a single level unit with a front push pad.
  • Non-Refrigerated
  • Stainless Steel
  • “Radii” Series
This Item Typically Ships in 1-2 Weeks
Posted on Monday, June 12, 2017 on product Oasis F140R NON-REFRIGERATED In-Wall Drinking Fountain
    There could be numerous issues causing the leak on your Fountain. We recommend calling to speak with one of our Drinking Fountain experts.
    Posted by Kully Supply on Monday, June 12, 2017
Posted on Tuesday, March 28, 2017 on product Oasis F140R NON-REFRIGERATED In-Wall Drinking Fountain
    There are a number of different parts or connections that could be causing the leak. The leak may be from a bad fitting which can be easily repaired or replaced.
    In order to make a recommendation you would need to identify where the leak is coming from by removing the panels on the fountain and looking on the inside.
    Posted by Kully Supply on Tuesday, March 28, 2017
Posted on Thursday, February 23, 2017 on product Oasis F140R NON-REFRIGERATED In-Wall Drinking Fountain
    A: There are a number of different parts or connections that could be causing the leak. The leak may be from a bad fitting which can be easily repaired or replaced. In order to make a recommendation you would need to identify where the leak is coming from by removing the panels on the fountain and looking on the inside. If you have any other questions our experts are here to help! Call or text 800-518-5388
    Posted by Kully Supply on Thursday, February 23, 2017
