Oasis PG8AC Drinking Fountain
  • Item #: 134416
  • Model: PG8AC
The Versacooler II Series is Oasis’ energy and water saving drinking fountain line featuring highly efficient bubblers and cooling systems. The series also complies with ADA requirements.
The PG8AC Water Cooler is a single level unit with front and side push bars.
Purchase an Oasis 035421-001 Adapter Bracket For PG8AC when replacing an existing P8AM. (NOTE: Cooler may not meet ADA height requirements when using the adapter bracket.)
  • Refrigerated: 8GPH
  • Sandstone
Availability: Ships Directly From The Factory In Approx. 3-5 Days
Posted on Monday, October 30, 2017 on product Oasis PG8AC Drinking Fountain
    Oasis has a 5 year limited warranty from the date the Drinking Fountain was manufactured.
    You can compare the visual differences between this Oasis PG8AC Drinking Fountain (Part #134416) to the Elkay EZS8L Drinking Fountain (Part #102357).
    Keep in mind, if you're replacing an existing Drinking Fountain, we recommend checking for a direct replacement with the same manufacturer to eliminate modifying the existing plumbing (waste outlet and water inlet).
    Posted by Kully Supply on Monday, October 30, 2017
Posted on Tuesday, March 28, 2017 on product Oasis PG8AC Drinking Fountain
    The Oasis PG8AC GoGreen VersaCooler II Water Cooler (Part #134416) weighs 59 pounds.
    The wall mounting bracket and fasteners are included with the fountain. The wall anchors, waste trap and supply stops would be furnished by the installer. The unit requires 115V of power that can be supplied by a standard plug-in outlet.
    Posted by Kully Supply on Tuesday, March 28, 2017
Posted on Wednesday, February 8, 2017 on product Oasis PG8AC Drinking Fountain
    A: The Oasis PG8AC GoGreen VersaCooler II Water Cooler (Part #134416) weighs 59 pounds. The wall mounting bracket and fasteners are included with the fountain. The wall anchors, waste trap and supply stops would be furnished by the installer. The unit requires 115V of power that can be supplied by a standard plug-in outlet. If you have any other questions our experts are here to help! Call or text 800-518-5388
    Posted by Kully Supply on Wednesday, February 8, 2017
